Excessive smoke
Old Aug 23, 2010 | 12:33 PM
safewiz's Avatar
Default Excessive smoke
I installed a DPF-R delete kit on a 2010 RAM 2500. I did not do anything to the EGR. Do I need to disable the EGR since I am recirculating exhaust back into my air box?
Old Aug 23, 2010 | 01:30 PM
Farmboy 2.0's Avatar
It shouldn't smoke hardly at all. Like we talking rolling coal or like a tiny puff when you hog stomp it or at start up?
Old Aug 23, 2010 | 04:01 PM
safewiz's Avatar
Smokes more than my 06 5.9 with 100hp added. Smokes when I ease in to accelerator really puffs when i get down on it. You can see a small amount of smoke just ideling thru the neighborhood. Acts like it is either getting to much fuel or not enough air. I don't know to much about the EGR on the 6.7. I thought this may could be the problem.
Old Aug 23, 2010 | 04:30 PM
That is strange i have not heard of that. I guess you could try deleting the egr. But that boggles my mind it smokes so bad
Old Aug 23, 2010 | 04:57 PM
300ft.'s Avatar
who's kit did you use
Old Aug 23, 2010 | 04:58 PM
NadirPoint's Avatar
Trying to do a regen cycle with no DPF might exhibit those symptoms. I'd expect to get the "see dealer" popup pretty soon. I think you need to do both deletes. Somebody who owns a 6.7 and has done the deletes properly should be able to provide more details/factual information.
Old Aug 23, 2010 | 06:42 PM
I know that we have had issues with the dpf r kits. With the truck still trying to regen and stuff. It would be interesting to see if you knew someone with a mini maxx to try that. and take the dpf r off and plug the mini maxx in
Old Aug 24, 2010 | 11:06 AM
Rouxlon's Avatar
From what I have read, you need to make sure you are doing the key cycle (10 or 15 seconds .. something like that) at least every couple hundred miles. I have also heard that the EGR valves can get stuck open and cause the truck to smoke really heavy. Doesn't seem likely on a 2010 truck but who knows. Another thing I read was that sometimes the black box that plugs into the OBD2 port can sometimes have problems and doesn't reset a regen counter and can cause the truck to go into regen ... might be that. Personally I would just give their tech department a call. I read some reviews on their site and they seem to be able to work out many of the problem people encounter.
Old Aug 24, 2010 | 11:26 AM
What color is the smoke is it white or black? I had an egr go out on my 2007 6.7 and it smoked white and alot of smoke and idled kinda rough
Old Sep 3, 2010 | 01:11 AM
6.7 MoJo's Avatar
From what I experienced on my 08 its the EGR. I did the delete w/Smarty and kept the EGR and it would roll random coal here and there on a small setting like SW3. I ditched the EGR and no more random coal. It would roll on the highway, no load 65mph on a 8 hr trip, just here and there all of suddon.
