6.5 Turbo, Turbo issue question
Old Aug 23, 2010 | 07:38 AM
travis174's Avatar
Default 6.5 Turbo, Turbo issue question
I have a 98 with 6.5l turbo and I have noticed lately when I am on the interstate it feels like the turbo is being bypassed. At about 70mph the turbo will spool up real fast then die then sppol up and die this will happen 4-5 times in about 15-30 seconds. When I step on it just feels like the turbo is not there. I did check the wast gate and it is not stuck and moves freely. The vacuum pump is working at and idle at least and easily works the wastgate. Is the a map sensor that is acting up or at higher rpms does the vacuum pump start to fall off? Any advise guys?
Travis
Old Aug 23, 2010 | 11:09 AM
Woody35's Avatar
wastegate system on these trucks is pretty bad and unreliable. have you checked the wastegate solenoid?
Old Aug 24, 2010 | 07:37 AM
travis174's Avatar
Yes I checked the vacuum solenoid on the turbo. It holds vacuum at any point along the stroke of the solenoid
Old Aug 25, 2010 | 06:02 AM
Livelli's Avatar
Get up with Heath and get a tubomaster. Everyone I've talked to has boasted about the improvement it's made on their turbo.
Old Sep 15, 2010 | 12:14 AM
Walking J's Avatar
A Turbomaster will help, but you'll also need a tune to run it.
Sometimes you can squirt WD40 into the wastegate solenoid and get them to work better. It is a sketchy system. If the turbo dies, there are better options.
Old Sep 24, 2010 | 02:55 PM
rick's Avatar
so would you remove both lines at the solenoid and squirt wd40 into the solenoid itself?
what about the lines?
Original_big_rod
Aug 21, 2016 02:30 PM
torg73
May 11, 2015 03:08 AM
greatlakes diesel
Feb 13, 2015 09:55 PM
Snoobly
Dec 11, 2014 11:59 AM
norcal6.5
Dec 7, 2014 07:04 PM
