starting problem
Old Aug 23, 2010 | 12:52 AM
wynooche willy's Avatar
Default starting problem
my 2003 dodge wont start with the key, it turnes over good but won't fire,
Ihave replased the transfer pump, and it still won't start. I was told tonight that the cummins has two oil pressure sending units, and if the one that goes to the computer
is not working it wont start.
In the chilton I have it only shows 1 sending unit.
I also replaced the cam sencer
any help wood be great
Old Aug 23, 2010 | 09:46 PM
dangerous1965's Avatar
Bad Key would start then shut down. Bad injectors would do it also and a PRV is also suspect! Can you get a pressure reading on the rail??
Old Aug 24, 2010 | 12:15 AM
Default 03 dodge cummins won't start with key
the engine does run and runs just fine, but it won't start with the key, it turns over but thats it!
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
