wait to start light 98.5
Old Aug 22, 2010 | 06:24 PM
chester601's Avatar
Default wait to start light 98.5
my way to start light does not go on , truck starts fine
where should I start looking ??/
thanks
Old Aug 22, 2010 | 07:16 PM
RAW's Avatar
RAW
Bulb in the back of the dash. The wait to start and high beam bulbs are the same. Swap them and see which one works, or doesn't work. Happened to me with my high beam indicator bulb. If you have an auto, make sure you disconnect the shift indicator under the steering column.
Old Aug 25, 2010 | 06:37 PM
mishkaya's Avatar
Just about has to be the bulb. If the light doesn't come on and it isn't the bulb, your truck wouldn't start...
Old Aug 25, 2010 | 06:47 PM
chester601's Avatar
thanks
I know this sounds stupid , how can I get to the bulb ??
Old Aug 25, 2010 | 06:51 PM
mishkaya's Avatar
Originally Posted by chester601
thanks
Have to remove the cluster panel. Not very complicated in all reality. Remve the dash bezel, it just pulls out, although you need to be careful not to break any of the tabs that hold it in. Then you will have access to the screws holding the instrument cluster in place. Once you remove them the instrument cluster will just pull out. It's a 15mn job at the most.
Old Aug 25, 2010 | 09:53 PM
RAW's Avatar
RAW
Hold on fella, one more VERY important step, if it's an auto. The cable on the steering column under the dash has to be loosened off and removed. this is the cable that indicates what gear you are in. I didn't know about it, and got a little too rammy and busted mine. I shift by feel these days.
schwier94
Sep 26, 2016 09:07 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
bullrideris1
Jan 23, 2015 09:22 AM
NCC74656
Nov 4, 2014 10:46 AM
