True Performance Diesel Visit - True Performance Diesel
TPD New Products
Old Aug 21, 2010 | 08:11 PM
TruePerformanceDiesel's Avatar
FormerVendor
Default TPD New Products
Announces Budget Intake Kits
Currently Available For:
94-97 Powerstroke Starting at $139
99-02 Powerstroke Starting at $259
94-02 Dodge Cummins Starting at $109
More Coming Soon...
All Intakes come standard with Aluminized Coating, but also available in Powder coat, Stainless Steel, Polished Stainless, or various Ceramic Coatings.
True Performance Diesel is proudly to offer:
TPD's High Pressure Crossover Lines for 94-03 7.3L Powerstrokes.
This simple upgrade will smoother idle, quieter injector operation and maintain even oil pressure on all injectors.
Don't be fooled be other kits using rubber hoses that deteriorate over time.
TPD uses high quality steel braided line and fittings.
Last edited by TruePerformanceDiesel; Aug 21, 2010 at 08:12 PM. Reason: Automerged Doublepost
Old Aug 22, 2010 | 02:16 PM
12vcummins96's Avatar
hey bud im curious on that system i have a 96 ctd do you have a pic of it for my truck and what filter does it come with thank you for your time
also noticable power gains and have they been dyno proven
Old Aug 22, 2010 | 11:57 PM
joebob3093's Avatar
Moderator
can i get some more info, specs and pics about the intake for the OBS?
Old Aug 24, 2010 | 04:53 PM
FormerVendor
The filter is a Donaldson hydrophobic filter. The same filter found on 17-18L Cat On Highway trucks.
As far as being run on dynos. They have been used on 600hp daily drivers to 1000+ full comp trucks.
Heres a pic of it.
Old Sep 2, 2010 | 02:12 AM
FormerVendor
Default Cummins Exhaust Manifolds
Now Shipping Cummins 2 Piece and 3 Piece Exhaust Manifolds:
12V $360 + shipping
24V $350 + shipping
CR $350 + shipping
Old Oct 12, 2010 | 12:57 AM
FormerVendor
Default TPD Duramax Headers/ Manifolds, EGR Deletes, High Flow Intake Bridges and much.
Coming in the next few days.
Getting the final prices and shipping figured out.
Anyone interested hit me up for more info.
Old Nov 9, 2010 | 09:29 PM
FormerVendor
Default Caltracs
Due to the high success and demand for Caltrac Bars on other forums over the last year.
We are now offering them on DB for an exclusive deal.
PM ME FOR DETAILS
Specializing in leafspring traction enhancement systems for over 15 years, the Calvert Racing Team knows what it takes to get your car hooking harder than ever!
With unsurpassed quality and craftsmanship, all competition is eliminated. Why settle for anything less than the original system that set the standards?
Calvert Racing’s CalTracs are the most innovative traction bar units today, often imitated, but never duplicated.
If you have a leafspring car, we have a set of bars for you! From daily driven cars, to 8-second outlaw cars, this system is made to out perform!
  • Complete bolt-on, no cutting, welding, or modifications to OEM suspension.
  • Keeps axle from rotating, helping maintain pinion angle.
  • Improves 60ft times.
  • Full preload adjustability.
  • Eliminates spring wrap-up.
  • Powdercoated gloss black finish.
  • Full color Installation Guide.
  • PSCA, NMCA, NHRA approved
Old Nov 15, 2010 | 10:39 PM
FormerVendor
Default Taking Pre-Orders on Engine Oil Change Valves
Introducing the best way to change oil, the Engine Oil Drain Valve. Install this valve and you can drain your engine oil without tools and without mess. Just lift the lever of this solid brass ball valve and give it a quarter turn to open it. Return the lever to its original position and it locks closed, double sealed to prevent leakage. The Engine Oil Drain Valve is made of corrosion resistant forged brass and stainless steel. The ball valve design provides a straight flow for efficient drainage and a perfect seal when closed. Frozen drain plug and stripped threads are eliminated forever. Drawing samples for oil analysis is as easy as one-two-three. Sizes to fit all cars, light trucks vans heavy-duty trucks and buses. Also fits RVs, marine engines and industrial equipment. (N-Series Valve(w/Nipple))
Available for Dodge, Chevy, and Ford diesels.
$24.95 and Free Shipping. Need 10 committed buyers before I can ship these out.
carid
Diesel Bombers Sponsors
Mar 20, 2015 08:03 AM
Mar 2, 2015 01:10 PM
carid
Nov 19, 2014 07:19 AM
Nov 6, 2014 08:10 AM
Allen@XDP
XDP Diesel Power
Oct 29, 2014 04:58 PM
