delivery valves
Old Aug 21, 2010 | 02:05 PM
new97dodge's Avatar
Default delivery valves
i was wondering if you could install laser cut DVs with stock injectors? and also i would like to no how much more fuel will flow. thanks
Old Aug 21, 2010 | 02:35 PM
captain_stabbin's Avatar
with better dv's you will get more flow to injectors, but not gonna help you with stock sticks! you dont need dv's to make more power
Old Aug 21, 2010 | 03:20 PM
cumminspwr11's Avatar
whats all done to your truck, laser cuts and a full cuts are more for competion, 191s, 181s, and .22 .24 are good for a dd, i would get bigger injectors before you start messing with the dvs imo
Old Aug 21, 2010 | 04:13 PM
blazier18's Avatar
check out southerndiesel.com for dv's and injectors but im with cumminspwr11 get the injectors you want then find dv's.
Old Aug 21, 2010 | 05:14 PM
12valvetater's Avatar
Delivery valves will flow more fuel even with stock injectors. As you go up in delivery valve size you inject fuel over a longer period of time.
Old Aug 21, 2010 | 05:41 PM
right, but all that fuel will do no good if you dont have enough air to go with it
Old Aug 21, 2010 | 06:08 PM
blazier18's Avatar
after u get injectors and delivery valves try a dodgezilla turbo there on citidiesel.net if injectors and dv's are as far as your goin with then it maybe a air intake
Old Aug 21, 2010 | 09:15 PM
The "dogdezilla" is an hx35 with a 60mm inducer.
Old Aug 21, 2010 | 09:17 PM
new97dodge's Avatar
thanks, i just saw that the DVs were pretty cheap and thought that it would b an easy way to make power, but i dont plan on doing much more than 75hp injectors and MAYBE a larger turbo... for now
Old Aug 22, 2010 | 01:26 PM
blazier18's Avatar
the larger turbo is the dodgezilla and the dv's and injectors im gettin from southern diesel if u aint goin over 75 horsepower go to citidiesel and look at the 370 injectors the only problem is the spray angle with them if u want 100 hp injectors go to pensacola diesel they have 100 hp remans for 200$ a set
