What are the symptoms of a dying IP?
Old Aug 21, 2010 | 12:21 PM
FordDZLMan9191's Avatar
Default What are the symptoms of a dying IP?
My truck is starting hard. I recently changed the return lines and fuel filter and everything is tight. The truck usually starts normal, but takes a few seconds of cranking. Glow plugs are still good too. The only other thing I can think of is that my IP is on its way out.
Old Aug 21, 2010 | 01:31 PM
DieselCrawler's Avatar
low power, hard start, smoking, knocking
any idea on milage of pump?
Old Aug 21, 2010 | 01:57 PM
About 160000 miles or so. I'm going to assume its the factory pump. The truck runs fine once its started and warmed up. No loss in power, knocking, or smoke. just starting the truck is hard.
Old Aug 21, 2010 | 04:15 PM
could be timing is off.
Old Aug 21, 2010 | 05:24 PM
Is that something a shop has to check and re-time or is it something I can do(with the help of my mechanic)
Old Aug 21, 2010 | 10:24 PM
Sycostang67's Avatar
What shape are the batteries and cables in? A really worn out IP will usually start ok cold but be hard to start hot. Thats not to say they wont just plain get weak over time/mileage. Before you start your truck the next time it's cold, check the fuel filter to make sure it is full.
Old Aug 22, 2010 | 12:42 AM
I could probably use a new set of batteries. Now that I think about it I'm willing to bet thats whats wrong. Anyone know what a set of Interstates would run me? Or what a cheap but still good set of batteries are?
Old Aug 22, 2010 | 12:26 PM
I grabbed a pair of batteries from schucks/O'reilly, $100 each, 1000CA. They work a lot better than the pair of 875CA batteries the PO had put in my truck.
Old Aug 22, 2010 | 12:30 PM
What brand were they?
Old Aug 22, 2010 | 09:01 PM
JC-6.9's Avatar
could anyone tell me how to adjust my injection pump timing? or how to check it...
