Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
what gear to pull in
Old Aug 20, 2010 | 10:00 PM
cummins-dodge's Avatar
Default what gear to pull in
i wa woundering what gear to pull in with the truck listed below with 35 bfg allterran and how much air pressure in the tires pulling tomorrow
01 dodge quad cab 5spd 275000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs, 300 hp injectors, s400 turbo and s300 twins, cooling mist water meth injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
Old Aug 20, 2010 | 11:00 PM
oglejust's Avatar
3rd low range
Old Aug 20, 2010 | 11:56 PM
bobcat67's Avatar
what he said, but i'm not so sure the siberian train horns are gonna help ya at the pull
Old Aug 21, 2010 | 04:13 PM
J-Pipes's Avatar
I run 3rd with the truck in my sig, I would think you could run 4th without much of a problem.
Old Aug 21, 2010 | 09:54 PM
1st_gen_puller's Avatar
dry slick 4th possibly 5th depending on your gearing.. wet sticky stay with 3rd.. low of course..
Old Aug 22, 2010 | 08:03 AM
i pulled last night 8/21/10 and i got 282ft 3rd place on a dry dusty track 3rd low 20 psi in front tires
01 dodge quad cab 5spd 275000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs, 300 hp injector, s400 turbo and s300 twins, cooling mist water meth injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
01 dodge reg cab 5spd 275000 miles cold air intake afe, cooler tubz, single electric fan, air dog 150, edge juice att. hot unlock, .093 connector tubes, valair single disc clutch, duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers
84 chevy k30 reg cab with 94 12v p pump cummins and nv4500 trans 205 transfer case 3 inch body lift, 6 inch suspension lift, 36x14.5x16.5 parnelli jones dirt grips, 16.5x12 weld scorpio wheels, dana 60 front, duramax rear axle, duramax intercooler, schied custom injection pump, 370 injectors that are extude honed bigger, o- ringed and head stud, marine lift pump, custom ground cam, cooling mist water meth. injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, valair hydulic upgrade, industrial injection silver bullet 66 turbo, no fuel plate, single 5 inch miter cut stack
03 honda rincon 650 1500 miles with 2 inch lift, 27 mudzillas, 1 1/2” rear wheel spacers, 1 inch front wheels spacers, hmf pipe, dynatek cdi, dynatek coil, k&n air filter, rejeted 170 main , spring clipped 8 coils, 5000 lb winch, heated grips, 14% gear reduction, 2 inch snorkel
95 yamaha warrior 350 bored out to 366, stage 2 hot cam, JE 85mm piston 10.5:1 compression, new rod, k&n air filter, white bros. pipe, bigger coil, performance cdi box, nerf bars, oil cooler mod
82 honda odyssey fl250 k&n air filter, dg pipe, rejeted FOR SALE
07 Kawasaki klx250 on offroad bike moose air filter, fmf pipe mostly stock
Old Aug 22, 2010 | 07:39 PM
i ran 55-60 psi in my rears and like 12 15 in the fronts..
Old Aug 22, 2010 | 09:34 PM
94 12valve's Avatar
very cool ... did you get a video?
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
rtbcoop
Nov 29, 2014 11:33 PM
james2562
Nov 2, 2014 08:31 AM
Oct 18, 2014 10:52 AM
