93 CTD severe injector pump leak
Hi I just bought a 93 and the injector pump is leaking very badly from between the pump and block, down about 2 inches and spraying into the block. I mean it's leaking a quart every minute? I looked at the sticky and it's in the area the "cover plate", that is held on by 2 torq bolts and looks like a "seal ring"
If so could the pump be clocked and allow the replacement of this O-ring seal?
There is a "slotted shoulder screw" could that be loose?
Thanks, Artie
Thanks, Artie
I know exactly what you are talking about. My truck had the same drooling problem when I got it(that's why I got it so cheap). Figures it's always the one between the pump and the block instead of the one that's out in the open. Anyhow, I ended up just taking the pump off and replacing the o-ring. I had to make a wrench to get that pesky third mounting bolt/nut off though. If I remember correctly I cut a 13mm box end about 2 inches long and then welded a 3" 3/8 drive extension to it(and then plugged my 12" extension into that one). Once I had my custom VE pump removal wrench, it was a breeze! If you choose to remove the pump, just remember to mark your timing etc when you take it apart.
Dec 5, 2014 08:30 AM
