pump question
Old Aug 20, 2010 | 08:29 AM
BAD ASS RAM's Avatar
Default pump question
how can you tell the difference in a 180 pump,215 pump,ect.???by looking at the pump
Old Aug 20, 2010 | 10:49 AM
93_Fummins's Avatar
I would assume you would more than most likely have to crossreference serial numbers...
Old Aug 20, 2010 | 11:02 AM
94 12valve's Avatar
pull the DV and look at the top of the plunger. if it has a retard notch its a 215, flat top could be a 180,175,or 160. you could also use the numbers on the plate if its still there
Old Aug 20, 2010 | 11:16 AM
Farmboy 2.0's Avatar
Yeah without taking the pump apart i would say the serial numbers
Old Aug 20, 2010 | 11:28 AM
94 12valve's Avatar
here are the common numbers found on the plate. there are others
if the last 3 are 885 or 911 its a 180 pump
if the last 3 are 887 or 913 its a 215 pump
landon025
Sep 8, 2015 09:21 PM
PA 24valve
Aug 31, 2015 06:08 AM
HardLuck
Jun 24, 2015 08:04 AM
ItsAChummins
May 15, 2015 05:02 PM
CJJD4640
9
Feb 9, 2015 07:22 AM
