need smoke
Old Aug 20, 2010 | 12:53 AM
Reather be cummin's Avatar
Default need smoke
Hey im new to this sit and i had a question i have a 95 cummins and i want some smoke im only 16 and learning about this stuff i have messed with the smoke screw but thats about it i could really use some help
Thanks dylan
Old Aug 20, 2010 | 01:01 AM
Bigred7.3's Avatar
Get a programer they have always done well with making smoke haha
Old Aug 20, 2010 | 02:18 AM
thanks man
Old Aug 20, 2010 | 02:53 AM
Captain Call's Avatar
Old Aug 20, 2010 | 09:02 AM
tiremann9669's Avatar
A programmer on a 95
Old Aug 20, 2010 | 09:07 AM
AF1CUMMINS's Avatar
That's f#$ked up man. Educate the kid a little, don't be a d!ck.
Old Aug 20, 2010 | 09:53 AM
well could you tell me anything sir
Old Aug 20, 2010 | 10:44 AM
93_Fummins's Avatar
First question is, why do you want smoke? Second question is, do you understand the pitfalls to having a smokey rig? Third question is, have you checked out the helpful hints in the 2nd Gen 12 valve section?
Smoke, albiet it "cool" to some, is in fact very hot. Black smoke is essentially unburned fuel exiting the engine thus resulting in very high exhaust side temperatures. A poorly tuned "smokey" diesel could have catastrophic results if not properly driven or re-tuned. If smoke is all you are worried about, you better have a spare motor ready...I have a melted piston to prove the point behind my theory. What you should be looking for is a balance of power, reliability, and maybe a little show off cloud now and then. Do you and your truck a favor and check out some of the threads in the section specific to your truck. Knowledge is the real power.
As a hint for your trusty '95...AFC, Fuel Plate, Smoke Screw, and GAUGES. Learn to master them in a responsible manner and you will get the power your desire.
Also, if you already have this diesel, don't post in "potential owners" thread...it just pisses off the mods.
Old Aug 20, 2010 | 01:18 PM
Farmboy 2.0's Avatar
I agree 100%. Get the knowledge you need before you screw with things. I don't wanna be a d!ck but we don't need a bunch of little kids running around giving us diesel guys a bad name. Set your truck up to be a clean decently powered truck that every once in a will you can puff a cloud of smoke
Old Aug 20, 2010 | 01:31 PM
jumpnjed's Avatar
For one thing a 95 12v cummins is a mechanical engine unlike the 24V. Use the search button for information on tuning your afc and slididng your fuel plate. Excessive smoke is just a waste and gives us all a bad name. I would get gauges first to monitor boost and EGT's before any mods. Then tune your afc as desired. Your actually getting off easy in this thread as I have seen others ask the same question and get butchered. Just do your research. And if you have an automatic you better be ready to upgrade, the stock dodge tranny is junk but with some good parts inside them they can hold some good numbers.
