Hardly any fuel to #1 cylinder
Old Aug 19, 2010 | 10:57 PM
1stGen1990's Avatar
Default Hardly any fuel to #1 cylinder
At work our 94 5 speed started missing today, had a fuel leak so we thought it was sucking air. Fixed it and bled the lines, still had it. We noticed the line to #1 had barely any fuel pressure at any rpm while the other 5 would squirt everywhere when cracked open. We also put on a new lift pump as well, it would die between shifts after pulling hard. Any idea why the injection pump aint puttin out much fuel on only 1 cylinder? Thanks
Old Aug 20, 2010 | 12:20 PM
stevenbrazell's Avatar
clogged injector?
Old Aug 20, 2010 | 12:52 PM
Farmboy 2.0's Avatar
Try taking the fuel line all the way off and blowing air through it. Just and idea that might be worth a shot
Old Aug 20, 2010 | 08:15 PM
95cumminsguy's Avatar
I would bet the plunger and barrel in the injection pump is bad, how many miles does that truck have on it?
Old Aug 20, 2010 | 09:54 PM
Red_Rattler's Avatar
High Tech Redneck
X2 to plunger being wore out
Old Aug 20, 2010 | 10:30 PM
white93's Avatar
Does the throttle get stiff when its acting up?
Old Aug 21, 2010 | 05:18 PM
12valvetater's Avatar
Plunger is siezing in the barrel. Classic effect of extended time with low fuel pressure.
Old Aug 22, 2010 | 05:30 PM
1stGen1990's Avatar
That makes sence because it was ran a while before they realized the fuel pump was out, i'll pull parts off our junker dodge to see. Its got a little over 200,000 miles. So does it need a new plunger to?
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
