i need twins!! 12 VALVE
Old Aug 19, 2010 | 09:24 PM
blazier18's Avatar
Default i need twins!! 12 VALVE
IM GETTIN READY TO STARTIN THROWIN THE FUEL. i got a 12 valve 98 model im goin to have my pump turned way up and run a no plate with 140 hp injectors high flow or laser cut dv's all the spring kits and valve kit. im tryin to reach anywhere from 550 to 600 hp maybe more if anybody has done all this and dynoed it. anyways i need to know wat turbo to go with to run all this fuel. i heard about a twin setup with a hx35 hybrid and a ht2b over under. if anybody can help me with a setup for turbo' or know anything else than injectors dv's and pump work to give me more hp and fuel than let me know. i would like twins but a big one would work i guess sorry for the paragraph just tryin to get everything in here i need
Old Aug 19, 2010 | 09:48 PM
oglejust's Avatar
A lot of ppl run the hx 35 with a ht3b
Old Aug 19, 2010 | 09:53 PM
RAW's Avatar
RAW
Yep, a HT3B or S400 will do the trick for a set of COMPOUNDS
Old Aug 19, 2010 | 10:41 PM
blazier18's Avatar
sounds pretty good i can get a ht2b turbo for 300 its on ebay rite now and i was gona make my hx35 a hybrid but where i could i find reasonable pricin on pipin for twins and would those turbos be good for 600 hp or could they go more
Old Aug 19, 2010 | 10:53 PM
12vcummins96's Avatar
not with a ht2b but with a 62/65/13 and a s480 you could do 750 sounds goooooooood
Old Aug 19, 2010 | 10:55 PM
94cummins12v's Avatar
im running a htb2 as a single alot of guys are go with the htb3 for twins
Old Aug 19, 2010 | 11:32 PM
blazier18's Avatar
well im kinda on a budget rite now i was gonna shoot to hybrid my turbo and get another for around 1500 in all. then start with the goodies but first im doin away with my allison 4 speed overdrive automatic for a nv4500 when i find one at a good deal. i have tons of questions about performance parts but thinks with the help on the turbo set up any more advice would be great
Old Aug 20, 2010 | 08:09 PM
cummins freak's Avatar
first off your 12v does not have an allison 4sp auto. second off you cant run a 2b under a 35 way to small 3b or s400 or in your budget range a good single you coud build twins off of later would be good.
you'll need to upgrade that little 35 with all the fuel you plan on running anyways way tomuch even in twins
Old Aug 21, 2010 | 10:23 AM
blazier18's Avatar
yeah its a detroit allison my bad and i found that out yesterday evenin that i need to run a s400 and make my hx35 a hybrid next i need to know where to get pipin for a reasonable price visionspeed or extremepsi maybe. and will i need to run head studs and how much smoke will my truck roll out with all this done im not wantin any negative attention but imthinkin 600 to 700 hp will throw it out
Old Aug 21, 2010 | 12:37 PM
94 12valve's Avatar
is this for your daily driver?
