p pump question
Old Aug 19, 2010 | 09:30 AM
BAD ASS RAM's Avatar
Default p pump question
hey guys i ran across a good deal on a p pump off a 2 ton truck,not sure what exactly,but just wanting to make sure it will work on mine before i buy it.
Old Aug 19, 2010 | 10:44 AM
blackout94's Avatar
any p7100 pump will fit as long as it is on a 5.9 cummins
Old Aug 19, 2010 | 10:59 AM
94 12valve's Avatar
why are you wanting to swap ppumps?
Old Aug 19, 2010 | 11:03 AM
i'm not just a steal and i know that a good used one is around 800
and do you think there would be any difference id dv's or anything else?and does it matter about auto/manual trans???
Last edited by BAD ASS RAM; Aug 19, 2010 at 11:03 AM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 11:24 AM
94 12valve's Avatar
it may have industrial DV's in it ... but I'm not sure
Old Aug 19, 2010 | 11:37 AM
how would i tell and when we pulled mine and they were 181's wich would be better?
Old Aug 19, 2010 | 12:59 PM
94 12valve's Avatar
stick with the 181's, the industrials look a whole lot different. Does the pump have bigger DV holders? looks like a .093?
Old Aug 19, 2010 | 01:20 PM
if it does i guess i should swap those with mine??
Old Aug 19, 2010 | 02:15 PM
94 12valve's Avatar
if there industrial holders they won't work with your 181 dv's.
IMO I think you should just use it as a core if its a 7100 style pump. otherwise I wouldn't bother buying it.
Old Aug 19, 2010 | 02:39 PM
i have 191's that i just ordered,would they work with them??
