Which dana 70 is it?
Old Aug 18, 2010 | 10:39 AM
Bombstack's Avatar
Default Which dana 70 is it?
Ok, I've looked around and didn't see a difinitive answer anywhere. Truck in sig, 1992 W350 getrag. Will it be equipped with a Dana 70, a Dana 70u or a Dana 70HD? Also, it's a 4:10 ratio. Why are there so many places out there selling 4:11 for this truck? Thanks!
Old Aug 18, 2010 | 11:41 PM
big bad diesel 416's Avatar
Site Sponsor
I belive it is the Dana 70 HD that is what I have been told anyway
Old Aug 18, 2010 | 11:58 PM
Bombstack's Avatar
Oops, it's a 3.54 ratio. I was think of my old CJ when I said 4.10. Anyhow, pulled the cover off and much to my dismay, there are 2 teeth sitting in the bottom of the case. They came off the pinion. So I guess my next question...... looks like I'm in the market for a 3.54 gear set. Do all three Dana 70 diffs use the same ring and pinion set? What is the going rate to have this done? If the price is too high, I'll teach myself how to do it(how's that for being tight!). Thanks again guys.
Old Aug 19, 2010 | 06:00 AM
oldgrey90's Avatar
yours is a 70u. hd's only came in some chassis cab and box van's, ups package cars. yeas all dana 70 gears are the same. the od of the inner pinion bearing it different between a u & hd. the id is the same.
Old Aug 19, 2010 | 06:45 AM
remps's Avatar
I thought 70u referred to the Dana 71 w/3.07's?
Old Aug 19, 2010 | 08:58 PM
Budgreen's Avatar
nope, 70u is the "light duty" version of it. that's what you have.
the pinion bearings are smaller, gears and all else is the same.
Old Aug 20, 2010 | 09:43 AM
Bombstack's Avatar
Well I guess while I wait for my ring and pinion to get here, I'll weld up the exhaust, beat on the turbo housing some more, disconnect my ABS box, clean the AC element, and install the hide-a-ball. All the things I've been putting off because it's 1000 degrees outside.
woodsman27
May 23, 2015 10:16 AM
tractormandan
Wanted To Buy (WTB) - Used
May 9, 2015 08:44 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
KYLEBOY
Jan 18, 2015 06:36 PM
gyayo2012
Nov 15, 2014 08:11 PM
