Turbo Overboost Code
Old Aug 17, 2010 | 12:12 PM
bobcat67's Avatar
Default Turbo Overboost Code
I have a smarty s-06 POD with Revo TNT and everytime I hit 40+ PSI of boost I get the Turbo overboost code, this only started happening recently when I updated the smarty, so I think it has something to do with that, I had a quadzilla boost fooler on it too and same thing, map sensor is new and IAT sensor is fine as well, I hooked it up to the snap-on verus scan tool to test these sensors and I know they're good, and I was told the smarty did boost fooling, checked for boost leaks there is none so I'm kind of at a loss as to what it could be other than when I updated the smarty something is causing it with the new tunes
Old Aug 17, 2010 | 12:20 PM
12vcummins96's Avatar
remove the quad boost fooler
Old Aug 17, 2010 | 12:23 PM
bobcat67's Avatar
I did, sold it too, but i'm still getting the code
Old Aug 17, 2010 | 12:26 PM
and your map sensor is in the parameters what did it ohm out to
Old Aug 17, 2010 | 12:30 PM
bobcat67's Avatar
I don't know my mechanic is the one that tested it and said it came up fine, he doesn't want me using the $10k dollar scan tool apparently, what really bugs me is this only started happening after the new smarty software, I wish i could go back a version and see if it is indeed it or if there is something wrong in the wiring of my truck
Old Aug 17, 2010 | 01:22 PM
try a smaller tune
Old Aug 17, 2010 | 02:22 PM
bobcat67's Avatar
ok I can do that and see how it goes over
Old Aug 17, 2010 | 03:23 PM
i would
Old Aug 17, 2010 | 08:00 PM
cerberus60's Avatar
Ummmm, thats your problem. You got rid of the boost fooler and Smarty does not boost fool. Put a fooler back on it or you won't ever solve the problem.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
