warrenty question
Old Aug 17, 2010 | 10:59 AM
830cummins410's Avatar
Default warrenty question
Ok I have an 07 with under 100k on it what does the factory warrenty still cover? It has a small tranny leak and the pinion seal is leakin on the front dif. Just wanted a little input before the dealership has a chance to lie to me. also what would cause the brake and abs lights to come on on the dash? I just put tires on it and while the wheels were off i checked and the pads and rotors look good. could they of been bad and the previous owner done them themselves and not had it cleared? If so how do i go about gettin them cleared? Thanks for the help in advance
Old Aug 19, 2010 | 04:40 AM
hendo's Avatar
i had the exact same thing with mine got it done under warantee
Old Aug 22, 2010 | 12:43 AM
ehaze's Avatar
i thought the motor was the only thing covered up to 100k??
Old Aug 22, 2010 | 01:19 PM
hendo's Avatar
so your think the the wiring harness that runs the motor is not covered ? they already replaced the computer saying that it is smog related but that is still electrical
Old Aug 22, 2010 | 01:52 PM
whitelightning's Avatar
Check your abs cable if some how it has been pinched of pulled loose it would cause it to light to come on.
Old Aug 22, 2010 | 02:53 PM
hendo's Avatar
would cause the motor to cut out momentarily on warm up ? or until its got to running temperature
torg73
May 11, 2015 03:08 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
countryboy040993
Dec 31, 2014 05:10 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
