2003 No power
Old Aug 17, 2010 | 02:50 AM
jpav161's Avatar
Default 2003 No power
so i just picked up a 03 3500 cc,sb fir fairly cheap. I was told the truck could use a fuel pump and a fan pulley, so i pick the truck up and drive it home and it has no damn power i get home check intercooler and intake boots, throw aairdog 150 at it and a boost and pyro gauge. take it for a run and still no power. Any suggestions on what it could be, it seems like it wants to run but just dosent
Old Aug 17, 2010 | 10:23 AM
dieseldude03's Avatar
Gonna need a bit more info. Does it smoke? If so, what color? What's your new gauges telling you concerning boost and EGT's? Start easy and idle smooth? Auto or manual trans? You've got the lift pump covered with the AirDog but what's your Rail pressure?
Old Aug 17, 2010 | 10:01 PM
jpav161's Avatar
It's a 6 spd, barely any black smoke on take off, dunno rail pressure, intercooler boost are tight, boost at shift point and wot is between 28-38, gets haven't gotten pas 1400, it has 223k on it
Runs and idle smooth, but it did shutoff twice when I stopped fast at stoplights
Old Aug 18, 2010 | 09:43 AM
Interesting. Any codes? Turn the ignition key, without starting the truck, from "Off" to "Run" 3 times... stopping on run. Any codes will be shown in the odometer read-out. Be a letter followed by four numbers i.e. P0049.
I think I'd find someone who can measure the rail pressure. Injection jump may be weak and not able to keep up with demand.
Old Aug 18, 2010 | 10:29 AM
Farmboy 2.0's Avatar
I agree with diesel dude i would try to find someone who can measure the pressure on the rail or see what it would cost for a rail pressure gauge and install it and see what it reads.
Old Aug 18, 2010 | 01:47 PM
jpav161's Avatar
ill try that today and get back to you guys by the end of the night
Old Aug 18, 2010 | 02:48 PM
Sounds good. You should see rail pressures approaching 23,000 psi at "Wide Open Throttle".
Old Aug 19, 2010 | 01:53 PM
Truckboy's Avatar
A lot of things, plugged air filter or fuel injectors, but Jeeps act strange with dead or low batteries.
Old Aug 19, 2010 | 02:05 PM
AF1CUMMINS's Avatar
Old Aug 19, 2010 | 07:23 PM
jpav161's Avatar
no one around here can do itt ill monday, ive checked all the hoses and clamps, and we pressure tested the system at the garage today, we couldnt see or hear any leaks but it too about 30-45 seconds and its went from 30 to 0.
explorer197143
Dec 28, 2014 01:14 PM
Dec 10, 2014 08:10 AM
