engine shake
Old Aug 16, 2010 | 08:22 PM
12valver85's Avatar
Default engine shake
my engine shakes when im in high gear and goin slow (its an automatic) but as soon as i get on it it stops.. not sure if its not gettin enough fuel or what the problem is
Old Aug 16, 2010 | 08:27 PM
95cumminsguy's Avatar
Mine did that too in the low rpm's after I bumped my timing up I had to adjust my AFC to give it a little more fuel with low boost to make it stop doing it hope that helps ya out a little
Old Aug 16, 2010 | 08:36 PM
12valver85's Avatar
thanks ill give er a try
Old Aug 17, 2010 | 09:24 AM
bigdan120's Avatar
1995 Auto Hey I have the same EXACT problem.....LOL But now as an added plus it is blowing blue smoke at start up and misses really bad until warm. I thought I had found the problem. Broken valve spring on cylinder 3 exhaust but that's fixed and it still does it.......
New injectors, adj timing, checked fuel pressure, changed fuel filters, changed oil, worked on the AFC.... Yeah I think I am experiencing a blown head gasket or cracked head...If you listen real hard when it is idling you can here something that just isn't right.Its like it is missing on 1 cylinder.........Not sure ! Let me know what you find......I will do the same...Mine will do it any time you are lugging it.
Mine will shake so bad that rust falls out and and my I cant even focus my eyes on the road LOL
Old Aug 23, 2010 | 09:07 AM
bigdan120's Avatar
Ok Updated! Pulled the head going to check valves tonight. Don't look like a bad gasket but I need to further my inspection. It looked like some of the material between the center cylinders is missing some of the gasket. The rings looked ok. Number six has some rust on it. Maybe anti freeze into cylinder ? It was not losing any though that I noticed. If I turn the head upside down and pour water in it that should work to see if I have a bent valve correct? Any info appreciated...
Old Sep 2, 2010 | 09:02 AM
bigdan120's Avatar
Ok update all my exhaust valves where leaking BAD.
Putting it together over this weekend.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
