not running well
Old Aug 15, 2010 | 10:53 PM
hulse09's Avatar
Default not running well
i hv a 00 cummins with 230k on it. it has edge comp drag box, boost fooler, raptor 150 lift pump, cold air intake, 5in turbo back. ok about a week and a 1/2 ago my truck started to run funny. it would skip when u really got on it. it was acting like it was starving for fuel, so i changed my fuel filter. my lift pump was running at 15psi and would drop to like 12 or so. so i turned the psi up to about to 18 thinking that was the prob. then i got reading and ppl said map sensor. so i went and got a new one along with a IAT sens but they gave me a wrong sensor. after putting the map sens in it still ran like ****. so i looked over everything wit my edge and nothing was wron no broken wires ect. but in the past few days it stopped skipping when getting on it but when i do get on it, it dose not have the power it did. befor i was pushing 35 or so psi and now i can hardly make 25. im wondering if its my edge or the IAT sens. so thoughts would be nice.
Old Aug 17, 2010 | 04:22 PM
RAW's Avatar
RAW
Any codes stored in the ECU? have you tried resetting your APPS? Just trying to throw ideas out there.
Old Aug 17, 2010 | 06:59 PM
hulse09's Avatar
well i had it checked and it said map sens to high for to long. seeing how im not running a boost fooler but have one now. so i replaced the map and AIT sens. and still dont have the power. like i said im not making the boost i was. b4 i could hit 35psi no prob. now i can onle get 25 or no. im starting to think its my edge comp box.
Old Aug 17, 2010 | 07:36 PM
turbo20psi's Avatar
Check the all the boots intercooler,turbo etc.Stock ones at 230k and 30+ psi may have ripped.
Old Aug 23, 2010 | 04:39 PM
hulse09's Avatar
Read more: https://www.dieselbombers.com/24-val...#ixzz0xT3HS4Nj
how do i rest my APPS??
Old Aug 23, 2010 | 04:52 PM
crzycummins's Avatar
i believe you turn the ignition on but dont start the truck...then slowly push the accelerator down and then let it back out slowly. that is the way i was told to do it anyway
Old Aug 24, 2010 | 04:07 PM
hulse09's Avatar
ok?? dk how it will work but tryed it and nothing
ssmith.77
Nov 25, 2018 06:56 AM
ROCKITV8
Jun 17, 2015 08:38 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
CumminsAtYa
Mar 17, 2015 09:23 AM
carid
Jan 12, 2015 04:32 AM
