Inside of tires balding
Old Aug 14, 2010 | 06:30 PM
ATX6132's Avatar
Default Inside of tires balding
the inside of both front tires are balding about an inch wide, the drivers side a little worse then the passenger side? 2004 f-350 dually 235-75-16 tires, only about 1000 miles on them. this happended to the last pair i bout as well. any help?
Old Aug 14, 2010 | 06:43 PM
tiremann9669's Avatar
Well you have a frontend, or alingment problem
Old Aug 14, 2010 | 06:52 PM
ATX6132's Avatar
i had a front end alignment done, it fixed it but bout 3,000 miles later again it happened
Old Aug 14, 2010 | 11:00 PM
ntmdtr3fan's Avatar
Id take it back to the place you had the allignment done. It has to be covered under some kinda guarantee??? Like 1 year or maybe a 10k mile? Sounds like you may have serverly worn tie rods or they were not tightened down right. They should also replace the tires since they obviously didnt fix the the allignment.
Old Aug 14, 2010 | 11:21 PM
X2
Old Aug 15, 2010 | 08:32 AM
olds442's Avatar
I would say you either have a bad or bent tie rod end. Or it could be the King pin bearings.
Old Oct 22, 2010 | 09:22 PM
cheepone2's Avatar
Ball joints or wheel bearings
bdemutis
Tire, Wheel & Suspension
Dec 28, 2016 07:35 PM
Jsully
Aug 31, 2015 07:55 PM
j_stroker
Mar 5, 2015 07:35 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Nov 20, 2014 11:20 AM
