93 GMC 6.5TD hard start when hot
Old Aug 14, 2010 | 04:53 PM
armenchiloyan's Avatar
Default 93 GMC 6.5TD hard start when hot
I guess its been a while since I requested help here, but running to a little problem. I got 93 6.5td that doesn't like to start when the engine is hot. I had replaced the Injection Pump about year and half ago, I was about 800 miles away from home when I first noticed this problem. I guess for some reason I got some cold water over the IP and it started right up. I replaced the fuel filter, Oil pressure sender switch, and the lift pump. I still have the same problem, and the cold water does the trick. Is it the IP again after barely two years of rebuild? I mean when IP is operating poorly I should have bad milage right? I got 530 miles on a full tank, so I don't know, if some one has any suggestions please let me know.
Thank you
Old Aug 16, 2010 | 08:47 PM
Woody35's Avatar
usually means the ip is going if it cant start hot but it does with cool water
Daniel Finney
Oct 22, 2019 01:58 PM
94turbostroker
Feb 26, 2016 07:51 PM
Accubuck
May 7, 2015 04:46 PM
Blanton
Apr 15, 2015 06:29 PM
trab123
Feb 9, 2015 09:44 AM
