DiabloSport PowerPuck
Old Aug 14, 2010 | 03:20 PM
24vmatt's Avatar
Default DiabloSport PowerPuck
1998.5-2000 24v cummins
DiabloSport applies the latest in digital technology to transfer the performance of the Cummings engine to another level. The PowerPuck remaps the fuel delivery of the diesel injection pump and advances the injection timing curve. The solid design of the PowerPuck is CNC-milled out of T-6061 Aluminum, factory spec interlock connectors and a completely sealed wiring harness which provides for superior durability and a state-of-the-art look. Why to get DiabloSport PowerPuck?
CNC milled 6061-T6 aluminum body construction
Factory spec interlock connectors and a completely sealed wiring harness
PowePuck installs in nine easy steps and in less than an hour, no wires to cut, no seals will be broken and no feeding wires through the fire wall
PowerPuck is designed to put no additional strain on the Diesel injection pump. The rotary VP44 injection pump in the 24V Cummins has a preset electronic limit to the amount of fuel it will deliver. Since the PowerPuck is plugged in between the ECU and the injection pump, the PowerPuck is programmed to never exceed that limit.
Dyno Tested Performance Tunes
The PowerPuck was created with one thing in mind, POWER!
Average power gains are in 50 HP and 125-ft/lb TQ. The additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A PowerPuck equipped vehicle will notice significant improvements in drivability. The additional power will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
PowerPuck tunes re-map the:
Fuel Curves
Timing Curves
$165.00 AND ITS UR'S
Old Aug 18, 2010 | 10:59 PM
24vmatt's Avatar
Old Aug 23, 2010 | 07:03 AM
24vmatt's Avatar
Originally Posted by 24vmatt
Bump
Old Aug 25, 2010 | 12:28 AM
24vmatt's Avatar
Old Aug 26, 2010 | 12:47 AM
24vmatt's Avatar
MAKE ME AN OFFER
Old Aug 26, 2010 | 12:51 AM
DB Admin's Avatar
Banned
Cummings
Old Aug 26, 2010 | 01:00 AM
big bad diesel 416's Avatar
Site Sponsor
Old Aug 26, 2010 | 01:02 AM
24vmatt's Avatar
Originally Posted by DieselMinded
Cummings
WTF is that suposta mean chad?
Old Aug 26, 2010 | 01:13 AM
DB Admin's Avatar
Banned
in the DiabloSport copy and paste product information you posted they spelled Cummins , Cummings
Odd from a big company like that dont you think?
Old Aug 26, 2010 | 01:17 AM
24vmatt's Avatar
indeed, i do think that is odd. Sharp eye buddy
in the DiabloSport copy and past product information you posted they spelled Cummins , Cummings
PASTE you mean mang...
