surging idle please help
Old Aug 12, 2010 | 01:16 PM
Rusty3538's Avatar
Default surging idle please help
I have a 99 dodge 2500 4x4 with 24 valve cummins. When I start it the idle surges between 600 and 800 rpms for approximately 30 sec or so then shuts off. i have replaced the lift pump and injector pump and the computer on the firewall I also have cleaned the IAT sensor stil having the same problem. Several dealerships have looked at it and thats why i replaced the parts that I did. Does anyone have any other ideas.
Old Aug 12, 2010 | 02:55 PM
crzycummins's Avatar
seems like there is air in the lines or a lack of fuel. but you replaced those so how is your fuel filter? have you checked for codes or have a way to check...thats a place to start.
Old Aug 12, 2010 | 11:45 PM
Rusty3538's Avatar
Sorry should have said that i did replace the fuel filter and there is no check engine light and when on a scanner there are no codes.
Old Aug 13, 2010 | 07:35 AM
RAW's Avatar
RAW
Have a fuel pressure gauge? Sure would be handy to know the pressure a the pump.
A little concerned as of why the PCM was changed, the ECU is on the side of the block.
Old Aug 13, 2010 | 08:01 AM
Rusty3538's Avatar
i have a fuel pressure gauge i'll hook it up and get back to you. I changed the PCM cause the mechanic at roger williams said thats what he was sure it was.
Old Aug 13, 2010 | 01:45 PM
you should have that gauge hooked up for monitoring all the time.
Old Aug 13, 2010 | 07:54 PM
Rusty3538's Avatar
I hooked up the gauge and it is showing 10 psi from the lift pump.
Old Aug 13, 2010 | 08:24 PM
thats at idle i assume? a bit on the low side if it is... is it a stock lift pump or are you able to adjust the pressure output?
Old Aug 13, 2010 | 08:28 PM
Rusty3538's Avatar
yeah thats at idle and yes its a stock lift pump
john grossman
10
Jan 12, 2019 08:58 PM
boneheaddoctor
Jan 15, 2016 06:19 PM
MechanicalDiesel
Aug 11, 2015 08:14 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
