wireing fuel pressure guage
Old Aug 12, 2010 | 09:24 AM
kerley's Avatar
Default wireing fuel pressure guage
I have a new pillar post cover,Gauge pod and Isspro Ev2 0-40psi fuel pressure guage. I have the new sending unit installed and I'm ready to complete the installation.
I have to ask, in your oppinion where is the best place to run wires into the cab from under hood. I dont want to start drilling holes for fear of creating a lot of unnessary damage. Any advise will be appreciated, Thank you, Kerley
Old Aug 12, 2010 | 11:13 AM
wyodiesel92's Avatar
You can run them through the bezel on the fire wall where the wiring harness runs to the fuse panel, its a tight fit to try and run wires with big hands like mine but you just make a little cut in that and run the wires through and crawl on the floor laying on your side and with a flash light you'll see where they are coming from. Now route them up either through the dash or along the side of the weather stripping on the door up to the gauge. I used the second method with my edge monitor and the weather stripping can be used to hide the wires to an extent going up to the pillar, if I managed with the huge wire to my monitor you should be okay with the wires running to the gauge. Either way make sure the wires are free of any moving parts so they don't get pinched. And that's all she wrote. Hope this helps.
Old Aug 12, 2010 | 12:06 PM
firstdiesel's Avatar
i ran my wires through the fire wall with another wire bundle, then up in the dash through the fuse panel area then up behind the pillar panel
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
