newcomer help
Old Aug 11, 2010 | 09:38 PM
new97dodge's Avatar
Default newcomer help
i recently slid the afc on my pump forward and it helped alot. i can now roll on the throttle in third and hold the brake and it will burn the tires. i was wondering what else i could do to my truck that would help it power and reliability wise while keeping it relatively stock. i have a 97 2500 12v 5 speed 4x4 the plate is out and i disconnected the wastegate and plumbed a boost gauge to it. im not sure how much boost it pushes, it will peg a 30 gauge before 2000 rpms in fourth gear wot. any help would be appreciated.
Old Aug 12, 2010 | 03:27 AM
97cummins's Avatar
You should put in an egt guage since you turned up the fueling.
Old Aug 12, 2010 | 05:05 PM
ArizonaRedneck's Avatar
yep egt gauge is a must
Old Aug 12, 2010 | 06:55 PM
Lange503's Avatar
egt and probably a bigger boost gauge seems how you can peg that one easily
Old Aug 12, 2010 | 08:37 PM
94 12valve's Avatar
hook your wastegate back up
Old Aug 13, 2010 | 05:26 PM
megacab's Avatar
before you should do anything you should look at getting a clutch
Old Aug 14, 2010 | 07:49 PM
new97dodge's Avatar
i was looking at clutches and i was thinking about a 550hp single disk from southbend, but im not sure if it would b a good fit because i drive it daily, my plans are to increase the timing, add either 100 or 140 horse injectors and get a larger turbo, not sure what turbo yet. i connected the wastegate and at full throttle you can feel the clutch wanting to slip in 5th but it doesnt yet. any input would be appreciated. thanks for the help.
Old Aug 14, 2010 | 09:15 PM
big willy's Avatar
straight pipe it if you haven't done that yet.
Old Aug 15, 2010 | 09:04 AM
wes-cummins's Avatar
bhaf, and a set of stix or dv's
