Coolant Bypass Kit
Old Aug 11, 2010 | 04:54 PM
bobcat67's Avatar
Default Coolant Bypass Kit
who makes a coolant bypass kit? or is it something most guys just put together themselves, and approximately how much does one of the kits run?
Old Aug 11, 2010 | 06:10 PM
Red_Rattler's Avatar
High Tech Redneck
Coolant bypass for blowout protection or for colder a/c?
BOE Kit
Old Aug 11, 2010 | 09:54 PM
00CamaroSS's Avatar
If your talking about colder A/C then check this out
https://www.dieselbombers.com/dodge-...nder-25-a.html
I did mine and dropped the A/C 12 degrees. Its easy and cheap I picked all the parts at the local hardware store.
Old Aug 12, 2010 | 12:12 AM
bobcat67's Avatar
talking about coolant bypass for blowout protection, but thank you i will look into both things, my blend door is broken on the AC system so it doesn't work that well anyway
Old Aug 12, 2010 | 12:22 AM
FastCR's Avatar
I can do that. come over with a ball valve and NIPPLES
Old Aug 12, 2010 | 09:20 PM
bobcat67's Avatar
I can take care of that Chevyboy
so what i've seen thus far is these kits seem to be very expensive for what it appears you're getting, most of it just looks like relatively simple parts, so why are they going for anywhere around $325-600. It's not about the money, but the majority of the stuff looks stupid simple, I guess I'm just looking for some input on why the things are so expensive, thank you for any response
so 2 people and myself have an interest in this? somebody has to be interested in this stuff
Old Aug 12, 2010 | 09:30 PM
94cummins12v's Avatar
go to puredieselpower.com and just get the blate that bolts in and get some heater hose from a hardware store
03-07 Dodge 5.9L Cummins Diesel Bolt-in Freeze Plug
heres the plate a barbed elbow is 99 cents and napa 5 feet of heater hose and another threaded elbow in the heat add a ball valve for 5 bucks build your own for less than 100 bucks
Last edited by 94cummins12v; Aug 12, 2010 at 09:30 PM. Reason: Automerged Doublepost
Old Aug 12, 2010 | 10:31 PM
bobcat67's Avatar
yeah that's kinda what i was thinkin, thank you, i just can't justify $600 bucks for shiny stuff when i can buy shiny hose covers for a fraction of the cost that people want for these kits
Old Aug 13, 2010 | 11:04 PM
that guy is smoking crack for wanting 325 for 12 bucks worth worth of galvanized and brass fittings worked at a hardware store for 9 years
Old Sep 1, 2010 | 03:25 PM
festes's Avatar
Like the pics of the a/c mod. do yall have some pics of the freeze plug block kit?
