Tranny has No Passing Gear
Old Aug 11, 2010 | 08:37 AM
jchavis's Avatar
Default Tranny has No Passing Gear
My 2001 Dodge Cummins automatic is having shifting issues and doesnt seem to have a passing gear.
I have to let up off of the throdle for the tranny to shift and if your going down the road and punch it it will not down shift or shift to passing gear.
Any help would be greatly appreciated, thanks!!!
Old Aug 11, 2010 | 09:36 AM
kazairl's Avatar
Have you tried adjusting the TV cable that goes to the transmission from the Throttle Position Sensor?
As per the Dodge service manual and most aftermarket tranny companies, The throttle valve cable should have no slack in it when the Throttle is in the idle position. Not to say that it is tight, but it shouldn't have any slack. You can adjust it by releasing the clip on the cable at the back of the TPS bracket and sliding the cable in or out.
How about resetting your apps?
Resetting Your Tps/apps - Competition Diesel.Com - Bringing The BEST Together
You might also try readjusting your TPS voltage.
Adjusting the APPS Voltage - Competition Diesel.Com - Bringing The BEST Together
AHAAN
Jul 19, 2015 10:28 PM
Jun 4, 2015 09:30 PM
tim12valve
9
Apr 21, 2015 05:51 PM
wilki
Feb 12, 2015 09:04 AM
rtbcoop
Nov 29, 2014 11:33 PM
