Auto Tranny To Stick?
Old Aug 11, 2010 | 12:18 AM
green thang's Avatar
Default Auto Tranny To Stick?
hey all i been thinking since my tranny is showing the signs on 250000 miles how hard would it be to stuff a 5 speed into the truck it's got the e4od in it now and it's 4wd. thanks tim
Old Aug 11, 2010 | 08:21 PM
Sycostang67's Avatar
Read this pretty much everything applies to your truck as well. This was pretty recent too.
https://www.dieselbombers.com/ford-8...-my-6-9-a.html
Old Aug 11, 2010 | 09:48 PM
JC-6.9's Avatar
yeah i just finished doing mine not to long ago...it wasn't as hard as i thought it was going to be other than my exhaust going to my turbo...i say go for it
Old Aug 11, 2010 | 10:42 PM
from what i can tell it will be a pain in the butt gotta put a cluch slave in (don't know what that is) and the pedals and also the tranny right? plus a new fly wheel? sorry not to filimilar with trannys. o and a got the non turbo and got a e4od now if that helps at all.
Old Aug 12, 2010 | 01:59 AM
tiremann9669's Avatar
The slave is the hydraulic cylinder that pushes the clutch fork, just find a donor truck that has all the parts you need
Old Aug 12, 2010 | 07:49 AM
ya planning on just finding a parts truck and grabbing everything that's attached to the tranny right? mu options are the c-6 only right? thanks for your support guys i'm only 18 and still kinda new to this.
Old Aug 12, 2010 | 09:29 AM
C-6 is an automatic, you're lookin for a ZF 5 speed
Old Aug 12, 2010 | 03:44 PM
o ok you guys reccomnd a 4 speed of the 5 speed? how about mileage with the standaed vs auto?
Old Aug 12, 2010 | 09:45 PM
JC-6.9's Avatar
if ur truck isn't turbo then it would be a breeze.....that was the only problem i had with my swap i thought it was going to be alot harder turned out to be pretty painless and it was def worth it
i haven't figured out my mileage yet but i can tell u i get way better mileage with the zf 5 speed vs the 3spd auto that was in the truck and i have my IP turned all the way up
Old Aug 12, 2010 | 10:55 PM
The auto you have now has a taller OD gear than a 5spd which usually gets better mpg at least as far as highway cruising. With 4:10's, 285's and a 5spd, I can get 17-18mpg out of my truck around town, I get about 14mpg on the highway.
