Need Idi factory turbo help
Old Aug 10, 2010 | 10:04 PM
tntstinomite's Avatar
Default Need Idi factory turbo help
I need help with my 94 idi turbo diesel. It is a k motor and has 110000 miles. The thing smokes crazy when I start it up blue and white. It also starts really hard. I also need exhaust work as it ends at the downpipe. What should I do to stop the smoking and how can I get it to start easier. Is my exhaust situation a big problem? I just need some guidance as to where I should start with repairs? I'm new to diesels so maybe just a general run over of a basic tune up i need to do would help.
Thanks,
Matt
Old Aug 11, 2010 | 08:26 PM
Sycostang67's Avatar
Sounds like you may have air intrusion and or need some new glow plugs. Check your return lines(hoses running between the injectors) to see if any are wet. If they leak, air gets in and your fuel flows away from the injectors. When you try to start it you have to wait for the fuel to build back up. A couple weak glow plugs will also make it difficult to start. Get a test light, hook the clip to the positive battery terminal and touch the other end to the top of each plug. If the light comes on, the plug works...at least a little bit. Only use Motorcraft plugs, the cheap plugs are prone to burning out quickly and swelling.
Old Aug 11, 2010 | 10:31 PM
What do u think about my exhaust bing cut off at the downpipe should I use a 4 inch exhaust? Also, I've been told I may want to get new injectors. Have you heard anything about the stage ones for the idis or should I go a different route?
Old Aug 12, 2010 | 11:02 PM
Your lack of exhaust wont hurt anything. A 3" exhaust will flow adequately, anything bigger and it's more for sound quality than function. I went with 4" and I dont regret it. If you are referring to the DPS stage 1 injectors, they will make more power(although not much), but also cause rough idle and constant smoke. I haven't run across anyone who was happy with them.
Old Aug 12, 2010 | 11:15 PM
What kind of injectors do you use and whats the difference between the bb and g code injectors
Old Aug 13, 2010 | 04:47 AM
DieselCrawler's Avatar
get a set or pressure matched bb code delphi injectors. bb flow the best.
Old Aug 14, 2010 | 10:43 AM
Where can I get the bb injectors and are you sure they work fine on a k engine? And are they alot more then the g code?
Old Aug 16, 2010 | 10:26 PM
The G code injectors were used in factory turbo motors, they are an emissions type injector and the worst ones you can put in your motor. Pretty much any other OEM injector will work good, BB codes just happen to be more prevalent. Getting a set of injectors that are pressure matched is a good idea though.
Old Aug 25, 2010 | 12:25 PM
So what store are they available at autzone etc? Also, once the truck starts it smokes blue and white everywhere? what might the problem be.
Old Aug 25, 2010 | 12:45 PM
cowboyford16's Avatar
sounds like you need glow plugs
