NEW FORD HPOP FOR 94-99.5 POWERSTROKE
Old Aug 12, 2010 | 02:56 PM
scott52575's Avatar
Banned
Default NEW FORD HPOP FOR 94-99.5 POWERSTROKE
THIS IS A NEW FORD HPOP NOT REMAN NO CORE CHARGE
REMANS GO FOR 561.00 PLUS 150 core ...so 710.00 for a reman if you have no core
I bought this pump accidentally and it would not work on my 2001 with split shots ..they are oil pigs older trucks use single shots and less oil I personally saw this pump output 2800 psi on my truck I drove it 50 miles and removed this is an excellent pump I also have a newer used working IPR for it for 100.00 if you buy it with pump so here's the price
pump 362 plus shipping 462 plus shipping with IPR installed
So call it 500 shipped to your door with a good IPR which goes for 280.00 from ford
First come first serve this fits 94-99.5 powerstroke 7.3's
unit will ship from cincinnati POSTAL MONEY ORDER ONLY
bumpity Bump come on some old school for guy needs this
buy my pump
Last edited by scott52575; Aug 12, 2010 at 02:56 PM. Reason: Automerged Doublepost
Old Aug 12, 2010 | 03:16 PM
gunman41mag's Avatar
Moderator
Old Aug 12, 2010 | 03:26 PM
scott52575's Avatar
Banned
thanks after all the bs ....happy to have someone bumpity bump
Old Aug 12, 2010 | 05:40 PM
Moderator
Who ever buy it is getting a GOOD DEAL
Old Aug 12, 2010 | 05:47 PM
CSIPSD's Avatar
buy my pump
2800 psi... but in this post you said 1500psi...
Put on the old wastegate it helped my boost some ....My engine runs below operating temp which means fuel plus air = burn = heat so maybe my rebuild is not so hot but before I do all the work to get them out and send them into jim for rework he has a flow bench so he says he would have done them for 500.00 labor and orings ect
I replaced springs in fuel side and all orings I pass buzz test mine were barely out of new specs on wear ....but hey live and learn I bought an a handheld O-scope so i can check my IDM output to each innjector I would hate to do all that work if it's IDM or PCM RELATED!!!!!!!!!!
Going to send my old HPOP in to Terminator to be modded for 100.00 see if he can get me from 2100 to 3000 psi would be nice!
hopefully the HPOP I installed can be returned ................362.00 if it was a pre 99 hpop thats why its 1500 icp is so low ....
FYI... This pump would be fine in a 94.5 to 97 PSD... I would NOT put it in anything not of OBS lineage...
Old Aug 14, 2010 | 07:25 PM
Moderator
Wow this hasn't been sold yet
Old Aug 16, 2010 | 05:38 AM
scott52575's Avatar
Banned
Everyone knows a 15 will not run split shots they are oil pigs this pump would hold 2800 PSI with my splits in stock mode with chip on 125 the pump would only hold 1500 ...why becuase it was not designed for a 2001 truck or split shots its for pre 99.5 motors with single shot injectors .....which btw use alot less oil than splits its why people are switching to splits less oil consumtion and better fuel pressure!
350.00 plus shipping ......also have a used working IPR for 100.00 if you want it combo deal
The pump is still for sale and ready to ship
payment can be made via postal money order why ....becuase it's a federal felony to committ MAIL fruad and the secret service comes after people who rip people off via a government sponsored money order its good for both seller and buyer give teeth to the law to bust people !
Old Aug 16, 2010 | 11:28 AM
CSIPSD's Avatar
This pump is a drop in pump for a 94.5 to a 97, 97 cali models came with split shots as well, and ALL SUPERDUTYS came with split shot injectors, from e-99 to 2003.
The only place this pump should be installed is on a OBS truck.
Old Aug 18, 2010 | 06:17 PM
Moderator
Old Aug 20, 2010 | 12:50 PM
scott52575's Avatar
Banned
By the way I just installed my modded pump 17 and it would only make 2000 psi ICP at wot
when I short circuited the coil on my IPR at idle this pump made 3160 PSI at 700 rpm
So that tells me either my pickup tube is clogged or my LPOP is worn out and aerating the oil or starving the HPOP under high rpm conditions which means either lpop is shot or my pickup tube is cracked or plugged
so bottom line anyone with an OBS truck this 15 HPOP I have is a great buy !
