80 HP Injectors
Old Aug 10, 2010 | 04:30 PM
williammiller's Avatar
Sad 80 HP Injectors
I have a 2001 quad cab 4x4 with 5" exhaust cold air intake, and i have superchips programmer and high preformance lift pump. I had 80 HP injectors installed by local mechanic and had no differance in power. Do I nees to get v44 pump reflashed or what do I need to do to get performance out of these injectors. I have been told it was just a waste of money. All they did was treat it like a car install the injectors and test drive it and hand me a bill. I don't think they know much about performance diesel trucks I live in Palm Coast close to Bunnell where they are suppose to have some very powerful dodge pulling trucks but cannot find anyone to answer my questions or to work on my truck.
Old Aug 10, 2010 | 05:02 PM
Codgedodger's Avatar
FormerVendor
You should have felt big difference are you sure that they even changed the nozzles? You don't need to re flashed, thats only if you have a problem with the pump.
Old Aug 10, 2010 | 05:19 PM
they gave me the old injectors. I had them install new 80 HP nozzles first but there was no differance in power. I thought maybe old injectors were holding me back so I bought new injectors thinking that would be better but still had no more power.
I have been told pump will still only supply same amount of fuel as with old injectors so i will not see any improvement in power until fuel is turned up.
Last edited by williammiller; Aug 10, 2010 at 05:19 PM. Reason: Automerged Doublepost
Old Aug 10, 2010 | 05:30 PM
FormerVendor
The pump will only supply the same amount of fuel even if you put 150hp injectors on a stock vp44 but you will still gain about 150hp... Its because now the orifices are now bigger, letting for fuel be pushed through them even though the same amount of fuel is coming from the pump. Does the truck blow black smoke with the 80s? And what brand are they?
Old Aug 10, 2010 | 05:57 PM
From Idle it will blow little black but soon goes to no smoke can't remember brand but they looked just like bosch stock injectors. fyi I am fellow hoosier from kokomo
Old Aug 10, 2010 | 06:22 PM
scottywiest's Avatar
man im sorry to say i think ur vp mite be getting weak!!! mine did the same now with the quad on 4 with stock injectors i can damn near cover an on ramp and i still have stock turbo and injectors... but mine did the same thing would only blow a puff if i really stood on it!!!! and got progressively worse as the pump died!!! new vp = new found power (missin soo long i got used to it)
Old Aug 10, 2010 | 06:47 PM
I installed a new vp44 pump (remaned) at the same time as the injectors from pensacola diesel did everything I could to prevnt having trouble.
Scottie are you near Palm Cosat?
Last edited by williammiller; Aug 10, 2010 at 06:47 PM. Reason: Automerged Doublepost
Old Aug 10, 2010 | 06:49 PM
i live in sebastian but for work i drive to whorlando or dundee everyday, im guessin palm coast is palm beach a west palm and all that?? sorry i dont know fl that well i been in GA and alabama for the past few years
Old Aug 10, 2010 | 06:51 PM
Anyone know where I can take truck to get diagnosed by someone that will be able to diagnose it correctly?
It is between daytona and st augustine.
Last edited by williammiller; Aug 10, 2010 at 06:51 PM. Reason: Automerged Doublepost
Old Aug 10, 2010 | 06:52 PM
is it runnin weak or missing or anything?? also are u runnin stock lift pump??? bc if u are u better be veryyyy carefull ur gonna kill ur vp again
