fuel pressure on my 03
Old Aug 10, 2010 | 01:34 PM
03dieseldaddy's Avatar
Default fuel pressure on my 03
i just installed a fuel pressure guage an it jumps from 12 to 14 alot an don't to 10 when i take off an at cruisen speed i think i need a better pump to keep up let me know what ur guys do an what kind of fuel presure u got.
Old Aug 10, 2010 | 08:04 PM
Billy D's Avatar
Bump, what about that Holley black, think it might be an issue. I haven't known anyone to have much luck with them. I thought they were fer gas.
Old Aug 10, 2010 | 08:51 PM
Codgedodger's Avatar
FormerVendor
I did to...
Old Aug 10, 2010 | 08:58 PM
its for all kinds of fuel the others r only for gas so i dont know
Old Aug 10, 2010 | 09:15 PM
FormerVendor
Can you adjust the pressure on it? I know on some models of the Airdog II you can...
Old Aug 11, 2010 | 03:22 PM
anwfarms's Avatar
you can adjust pressure on the black. you got the plug on the side of the pump. pull it off and there is a spring behind it. stretch that spring put it all back together and check your pressure.
Old Aug 11, 2010 | 03:39 PM
NadirPoint's Avatar
Unless you're running a pair in tandem, I wouldn't trust those Holley or similar knockoff types for anything more than a backup.
Old Aug 14, 2010 | 09:01 AM
stretchd the spring out got me 4 more psi but still gonna go with an airdog2
Old Aug 14, 2010 | 05:10 PM
mxtuner1's Avatar
This is my opinion - I used a FASS 150 on another truck worked well. Original Airdog should be a little better - he owns the patent on 2 air removers - the FASS has one. Plus the Airdog 2 has regulated fuel return - I want a lot of fuel to the pump as it cools and lubricates the pump and the more times your fuel goes through the filters - the better polished it will be. Plus the Original airdogs are at a steal price right now below $500!
Old Aug 19, 2010 | 01:52 PM
Truckboy's Avatar
you need at least 43 to run it on properly,normally they run around 45-50 pounds,but if you got 43 it will run right,good luck.
