Trans Temps ?
Old Aug 10, 2010 | 11:03 AM
ROCKITV8's Avatar
Default Trans Temps ?
What are normal auto tranny temps ?
Old Aug 10, 2010 | 11:05 AM
NadirPoint's Avatar
If you mean the 48RE, 150-170 in the pan.
Mine runs around 160 with a Maghytec DD pan, which I belive keeps it about 10 degrees cooler than stock on continuous cruise average.
Old Aug 10, 2010 | 03:05 PM
ROCKITV8's Avatar
Mine runs between 185 and 195 with a stock pan, that is what my Edge display says? I was just wondering if this is normal?
Old Aug 10, 2010 | 07:42 PM
mxtuner1's Avatar
I think the juice w/ attitude reads a little high on transmission temp. When you put a deep pan like the other gent- your sending unit is directly in the pan fluid. I think the juice gets a reading from the computer and its reading is taken where there is more air in the tranny - like near the selenoids and it will read higher. As long as not cotinuously over 200 all is well. Drive it like you stole it!
NadirPoint was the other gentleman - not to just call him "the other gent"
Old Aug 10, 2010 | 09:46 PM
cerberus60's Avatar
Thats normal. The temp read from the OE sensor seems to run 10-15 degrees higher than an analog. I see those temps in the hot line. Thats about the middle of the range for ATF+4 so its good.
Old Sep 13, 2010 | 07:54 PM
cummins0331's Avatar
mine runs about 160 165 and i have a stock pan but when i stop for ahwile she usually runs 180
Old Sep 13, 2010 | 08:18 PM
reiser's Avatar
Miller Lite Drinkin'Coach
since i had my tranny built I've seen 165 one time pulling, normal for me is about 130
Jake9473
Jul 22, 2018 08:19 AM
ctd04x4
Sep 11, 2015 03:50 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
wisakowsky
Diesel Engine Conversions
Oct 14, 2014 08:13 PM
Pyrohigh
Oct 11, 2014 07:59 AM
