2005 6.0 won't start
Old Aug 9, 2010 | 09:53 PM
Crewcab's Avatar
Default 2005 6.0 won't start
i've got a 2005 6.0 that won't start unless you give it a shot of ether then runs great but then it will also just die going down the road occasionally won't start with out ether then will run fine after running. i have replaced the cam sensor changed oil and fuel filters also.
Old Aug 10, 2010 | 08:01 PM
newman's Avatar
DON"T spray anymore either in it! You need to get a scanner and see what your ICP is while cranking. Also you can try unplugging the ICP sensor and see if it will start.
Old Aug 10, 2010 | 09:05 PM
Crewcab's Avatar
Where is the icp located at ? I know i shouldn't use either but it beat walking at the moment. Thanks for the advice will check this out.
Old Aug 10, 2010 | 09:54 PM
newman's Avatar
Its in the passenger side valve cover. I want to say they will start on WD40 and it is easier on the engine
Old Aug 10, 2010 | 10:16 PM
Crewcab's Avatar
Thanks i appreciate the help will be checking it out tomorrow.
Old Aug 12, 2010 | 08:11 PM
newman's Avatar
Any update?
Old Aug 12, 2010 | 08:32 PM
Crewcab's Avatar
started fine this morning then wouldn't start after it was warm even after setting 2 hours . Feeling kinda dumb but i couldn't locate the icp. Also i was going to add i had a edge box on it when this all started but that was the first thing i removed when i started trouble shooting.
Old Aug 13, 2010 | 07:35 PM
newman's Avatar
It is a grey plug on the passenger valve cover towards the front of the engine. I think your gonna need to put a scanner onthe truck to get anywhere if unplugging the ICP doesn't cause it to start.
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
keith63
6.0L Performance
Mar 18, 2015 12:35 PM
thumperf350
Jan 8, 2015 12:55 AM
