injectors are in!
Old Aug 9, 2010 | 01:18 PM
yvillanz's Avatar
Default injectors are in!
im putting a new set of dephi injectors in today any helpful tips or tricks or special tools i should try?
any input helps
Old Aug 9, 2010 | 08:05 PM
poocher pup's Avatar
vasoline on the o-rings seems to make tee caps go on better .
Old Aug 9, 2010 | 08:14 PM
blackcloud21's Avatar
hey dude i got an 88 f250 let me know how those injectors work out.
Old Aug 9, 2010 | 08:31 PM
MossBack's Avatar
vegetable oil wont swell the o-rings. If u are replacing the return line. I recommend takin the old one off and building the new one like it. Makes it easier when going back together.
they work good. but turning up the pump works much better. I replaced all of mine as they were cracked and leaked. (Long live the 91)
Old Aug 9, 2010 | 11:20 PM
Sycostang67's Avatar
A shotgun cleaning kit will help to clean out the injector bores. Dont overtorque the injectors or you will distort the copper washer and cause a compression leak, 35ft-lbs is the needed torque. A deep 1" socket is most helpful.
Old Aug 11, 2010 | 08:28 AM
yvillanz's Avatar
i got a new return line kit
so me and my buddy popped in the new injectors that thing is an animal!
Old Aug 11, 2010 | 08:18 PM
Make sure you get the timing checked, new injectors will change it. When I replaced my injectors it caused my timing to be 4.5* too advanced.
Old Aug 11, 2010 | 11:57 PM
yvillanz's Avatar
Is this something I can do my self
Old Aug 12, 2010 | 01:13 AM
Rogers21's Avatar
boy that'll be nice when shes done
Old Aug 12, 2010 | 10:59 PM
If you have the money to spend on the equipment, and it isn't cheap. I just took my truck to a shop, only cost an hour of labor.
