TPS died again
Old Aug 9, 2010 | 03:20 AM
jt2248's Avatar
Default TPS died again
The TPS on my 99 went out about 6 months ago and has now died again. Has anyone experienced this issue? I am concerned there is an electrical issue.
Old Aug 9, 2010 | 07:26 AM
turbo20psi's Avatar
Start by checking the ground on the batteries and the ground from the TPS(APPS).
Old Aug 9, 2010 | 07:52 PM
farmboy458's Avatar
apps are junk 0n these things where did you buy the last one from?
Old Aug 12, 2010 | 08:52 AM
jt2248's Avatar
Geno's garage in GA. However someone smarter than me reminded me that I needed to reset the APPPS after disconnecting the batteries. I am back in business. I think there is something going on with the alternator causing an electrical surge.
Old Aug 13, 2010 | 04:35 PM
kerley's Avatar
Default APPS
What is APPS, how do you reset it?
Old Aug 14, 2010 | 08:05 PM
jt2248's Avatar
APPS (Accelerator Pedal Position Sensor ) or TPS (throttle positions sensor). to reset disconnect batteries for about 30 min. reconnect batteries, turn ignition switch to on, do not start. depress the accelerator pedal to the floor slowly and release slowly. Fire it up
taweste
Aug 29, 2015 02:34 PM
moose2j
Jun 21, 2015 12:36 AM
Seann12
Jun 17, 2015 10:40 AM
RayRay4991
Feb 23, 2015 07:45 AM
Genghiscarl
Oct 27, 2014 10:19 AM
