internal pump pressure
Old Aug 8, 2010 | 09:15 PM
stillcummin's Avatar
Default internal pump pressure
anyone playing with internal pump pressures on the ve.This is most important part of getting good performance out of your pump.And its adjustable!!!
Old Aug 8, 2010 | 09:18 PM
Begle1's Avatar
Yes. The higher the better. Run a fuel cooler. Adjustability is irrelevant at RPM with injectors.
Old Aug 8, 2010 | 10:46 PM
6btDakota's Avatar
how do you go about raising the pressure choking the return line?
Old Aug 9, 2010 | 05:21 AM
theres a regulator valve by the fuel intake.The ksb runs into it.Now this is very precise adjustment.if you go to far you'll have to remove it .The bosch technicians use a tool that pushes it down with a bolt,but you can tap it as well.You also need a way of measuring the pressure ,through the return banjo bolt is a good spot.
VWDieselParts.com :: View topic - internal injection pump pressure
I dont know if i ever posted this here.May the force be with you.
Last edited by stillcummin; Aug 9, 2010 at 05:21 AM. Reason: Automerged Doublepost
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
ramrunner01
9
Jun 4, 2015 03:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
veggyoilkid
Nov 10, 2014 12:39 PM
