All The Symptoms Of A Head Gasket, But Its Not
Old Aug 8, 2010 | 08:29 AM
00cummins00's Avatar
Default All The Symptoms Of A Head Gasket, But Its Not
ive got a 00 3500 cummins, i had lots of oil in the water, enough water in the oil to cover the inside of the valve cover and burning water. so i put in a new head gasket had the head surfaced and magnafluxed, no cracks. i still have all the same problems even tried that crap in a bottle to stop leaks in the water system. any ideas?
Old Aug 8, 2010 | 09:09 AM
RAW's Avatar
RAW
Oil cooler would be my guess. My tech manual has very limited information on it, but it looks like it is part of the oil filter assembly, or mounted to it. If your lucky, blown gasket, otherwise it is the element it's self. Only one way to find out, start draining everything, again. The tech manual does state to check the element with 70psi of compressed air.
Old Aug 8, 2010 | 09:33 AM
BlackCloud96's Avatar
oil cooler x2
Old Aug 8, 2010 | 10:27 AM
00' Quad Cab's Avatar
Oil cooler would be my guess as well.
Old Aug 8, 2010 | 10:47 AM
any ideas on the water burning, burn about 1 gal every 75-100 miles
Old Aug 8, 2010 | 10:58 AM
RAW's Avatar
RAW
It is probably boiling out of the oil, and escaping through the breather/slobber can. Engine oil at operating temperature is hotter than water boiling point.
Old Aug 8, 2010 | 05:34 PM
tiremann9669's Avatar
Crap in a bottle
Old Aug 11, 2010 | 03:26 AM
but im smellin it in the exaust.....
Old Aug 11, 2010 | 06:42 AM
turbo20psi's Avatar
Block must be cracked between the water jacket and cylinder(piston).Have you checked the block for cracks.
Old Aug 12, 2010 | 02:32 AM
nope, would i need to pull the motor to rtake it to a shop?
