Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Pulling Rules
Old Oct 13, 2007 | 08:10 PM
LOGANSTANFORTH's Avatar
Default Pulling Rules
i am writing a set of rules right now for some of the guys down in florida, here is what ive got so far, tell me what you think as for classes. weve been doing our own pull for about 10 years back in ohio and im using alot of the rules with the addition of some of mine to tweak them.
stock turbo class (duramax class LOL), 8500LBS, traction bars, 2.5 inches of travel and no hanging weights, NO WATER, 1 ton or less factory drivetrain. no externally modified injection pumps, nothing through the hood, engine must look stock, must have stock interior, must run on diesel only.
REST OF THE CLASSES WILL BE 8000LBS 8500 lets crewcab duallys in the stock charger class.
2.5 inlet wheel, with 1.5 inch of travel and hanging weights, NO WATER, 1 ton or less "factory" drivetrain, no externally modified injection pumps, nothing through the hood, exhaust must exit up or down, must have (2) 3/8 cross bolts in exhaust, engine must look stock except turbo, must have stock interior, must run on diesel only..
stock and 2.5 is only allowed 1 injection pump, and pump must look stock
3.0 inlet wheel, can have rearend bolted solid, WATER ALLOWED, 1 ton or less drivetrain, gutting of interior allowed, must run on diesel only..
limited twins, 4 inch atmosphere charger, can have rearend BOLTED solid, WATER ALLOWED, 1 ton or less "factory" drivetrain, gutting of interior allowed, must run on diesel only.
super street, requires the use of a 1 ton or less front axle, trans, frame, and body, do what you please from the rear of the transmission drivetrain wise, gutting of interior allowed, WATER ALLOWED, must run on diesel only.
modified, truck must use a "factory" (ag, industrial) block and head, no aftermarket head or blocks, WATER ALLOWED, must run on diesel only.
NO DRUGS......KEEP THE METH HEADS AND BOTTLE BABYS ON THE TRAILER
ALL TRUCKS MUST HAVE THE PROPER SAFETY EQUIPMENT, ANY BIGGER THAN STOCK AND 2.5 MUST HAVE KILL SWITCHES, DRIVESHAFT LOOPS, BLOWPROOF BELL HOUSING/SCATTER BLANKETS, ALL TRUCKS MUST RUN ON DIESEL ONLY
Old Oct 13, 2007 | 09:25 PM
IC Smoke's Avatar
A good rule up here is no smoke after the 50' marker or its a instant DQ no questions asked
Old Oct 13, 2007 | 09:53 PM
DazedandConfused's Avatar
For what class?
Old Oct 13, 2007 | 09:54 PM
thats ok if we are running a pure stock class, but stock is just too hard to mess with cause its too hard to police it. I EDITED SOME OF THE RULES..
Old Oct 14, 2007 | 06:02 PM
IC Smoke's Avatar
the stock class....
Brclouse
Nov 18, 2015 08:44 AM
oneloud59
May 16, 2015 10:00 AM
DetroitDiesel
Jan 29, 2015 08:13 AM
Nov 3, 2014 12:50 PM
