4x4 tilt steering column
Old Aug 7, 2010 | 09:06 PM
tedge's Avatar
Default 4x4 tilt steering column
Help ANY one out there have a good used steering column for a 91 to 93 dodge pickup..
Old Aug 8, 2010 | 02:36 PM
Onemoparnut's Avatar
Stick or auto?
Old Aug 8, 2010 | 03:03 PM
tedge's Avatar
Default tilt column
thanks for the reply It is a auto, need column or lower bearing at base of steering column Thanks todd
Old Aug 8, 2010 | 09:16 PM
I have one out of a stick 93
Old Aug 8, 2010 | 09:33 PM
tedge's Avatar
Is it a 4x4 column any idea what it is worth
Old Aug 8, 2010 | 09:40 PM
tltruckparts's Avatar
i got 200 a piece for the last 3 i had if that helps
Old Aug 8, 2010 | 10:11 PM
6btDakota's Avatar
I have one but its from an 89 auto 4x4 and i dont know if the bearing is good. let me know how to check that bearing out and i can get it to you cheap if its in good shape. truck had 115k but steering was shot i think most of it was in the steering box and joint tho.
Old Aug 9, 2010 | 07:05 AM
I don't know what it is worth. Make me an offer.
Old Aug 9, 2010 | 02:45 PM
Mark Nixon's Avatar
This should probably be in "Parts Wanted".
If you're going to completely replace it, you need a column shift column from a '92 or '93.
The clockspring on '91 is different, but the column will work if you use your clockspring and steering wheel from your '93.
There is no difference from 2wd to 4wd, it's auto to manual that is different.
I can supply a BARE tilt column assembly from an auto, if you want to go that route.
You can use your covers, steering wheel and electrical components.
You'll need to invest in a set of tamper-proof torx drivers to remove the ignition switch and multi-function switch.
PM me for my price on a bare column.
I generally don't like to post prices in an INFORMATIONAL thread.
Mark.
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
daniel2500
Apr 23, 2015 11:15 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
