I want to know.
Old Aug 7, 2010 | 04:18 PM
01quadcab's Avatar
Default I want to know.
I want to know who out here has, or had a in tank pump installed as a fix to the original block mounted lift pump. How long did it last for you? How much fuel pressure did you have? I left the other thread alone because I would like some info to see how many of there are in use, or how many have failed. But according to one individual I don't know anything about a in tank pump. So please anyone who has had one or knows anything add it to here. I myself think the in tank pump is junk.
Old Aug 7, 2010 | 04:37 PM
RAW's Avatar
RAW
I completely agree that the intank pump is crap!! When I bought my truck that is what it had in it, but I'm not too sure for how long. It made very poor flow, therefore low pressure. With the Edge on level 1 and not too heavy of a foot pressure would drop to 4psi from 14psi at idle. Any harder acceleration it would drop to 0.
I had Chevy gas trucks in the past, and everyone of them has gotten at least one in tank pump changed. IMO, since the mechanical block mounted or IP mounted pumps became a thing of the past, fuel pump quality and reliability from a vehicle manufacturer has dropped significantly.
Old Aug 7, 2010 | 04:52 PM
turbo20psi's Avatar
I had the block mounted pump in the 02 and it fail under warranty so dodge put it into the tank well it fail 8 months later,back to dodge for the second intank pump lasted 1 year===FAILED.Then I just put a FASS on it and its still running strong its the older one thats a little noise.This pump is on heavy modified truck.
Intank pump doesnt last to long IMO.
Old Aug 7, 2010 | 06:12 PM
There junk just like the other stock Carter pump.
Old Aug 7, 2010 | 08:22 PM
01cummins13's Avatar
junk junk junk there was one my truck when i bought it and it was on its last leg
Old Aug 7, 2010 | 08:31 PM
captain_stabbin's Avatar
external pump is the way to go!!!!
