edge juice
Old Aug 6, 2010 | 02:53 PM
jtcummins's Avatar
Default edge juice
I just got an ejwa. I was wondering how long can i run it before i need to get a fass fuel system or air dog? I was thinking about just getting a ppe i think it is? just till i get the money to get somethin better.
Old Aug 6, 2010 | 03:36 PM
RAW's Avatar
RAW
Yikes!!! Running an Juice or any performance mod without an upgraded lift pump is risky! Watch your fuel pressure, don't let it drop under 10PSI with the engine running EVER. Damage to the VP44 will occur. A AirDog Raptor, or FASS DDRP would be a cost efficient way to keep fuel pressure where it needs to be, and doesn't require dropping the tank.
Old Aug 6, 2010 | 11:39 PM
01quadcab's Avatar
whats your fuel pressure at? If you can maintain at least 7psi at wot you will be ok. But in most cases you can't run it over level 1 or 2 without chance of pump failure. Don't waste your money on a ppe. save your cash and get a good system it's worth it especially with the smaller micron filter. I myself like fass but I know a lot of people run airdog too. Lifetime warranty means a lot.
Old Aug 7, 2010 | 07:43 AM
jtcummins's Avatar
well i think im gonna hold off on puting the chip in till i get somethin but thanks for the help
Old Aug 7, 2010 | 04:20 PM
01quadcab's Avatar
you can add the chip but don't tap the pump wire and it should be ok. your better off to have some gauges than nothing at all.
Old Aug 7, 2010 | 04:48 PM
RAW's Avatar
RAW
Thanks a very good point! You can have all of the features, but no power gain. Then the temptaion will be removed and possible damage avoided. When you do tap the pump, I strongly suggest a Steakth Plate so no external wires have there insulation punctured.
Old Aug 8, 2010 | 03:59 PM
jtcummins's Avatar
thanks and i got a smokin deal on a FASS ddrp, with some gauges pyro,boost,trany temp, fuel psi
Old Aug 8, 2010 | 05:43 PM
RAW's Avatar
RAW
Old Aug 8, 2010 | 07:51 PM
The FASS DDRP is fine for a stock truck or a truck with a small box.
Old Aug 8, 2010 | 11:45 PM
24vmatt's Avatar
how about the Raptor, or a bd aux lift pump?
