Diablo Sport Power Puck
Old Aug 6, 2010 | 12:49 AM
24vmatt's Avatar
Default Diablo Sport Power Puck
just got it about a week or 2 ago, and i just won an edge juice with cts, so i want to sell it.
For 1998.5-2000 24v cummins
$180.00 and its yours.
Diablo Sport has designed the POWER PUCK for the in-line, six-cylinder, direct-injection, turbo diesel Cummins engines. The POWER PUCK gives maximum power and torque without compromising reliability. The POWER PUCK is designed of 6160 Aluminum for durability and looks. Its compact design allows the unit to install easily. Installation is quick and simple. Once the POWER PUCK is installed you will be able to feel the difference. The torque and horsepower gains are felt immediately throughout the entire rpm range. The significant torque created in the low to medium range helps out in the most critical times such as when passing a vehicle while you're out on the road or while you're pulling a heavy load. When you demand performance, the Power Puck responds.
Old Aug 7, 2010 | 01:38 AM
MasterLow's Avatar
Bought mine new for $170 shipped...
Old Aug 9, 2010 | 03:52 PM
24vmatt's Avatar
sweet, I diddent.
They sell for 225. check it out
Rollin Smoke Diesel. 1998.5-2000 5.9L 24V Dodge DiabloSport PowerPuck
DiabloSport applies the latest in digital technology to transfer the performance of the Cummings engine to another level. The PowerPuck remaps the fuel delivery of the diesel injection pump and advances the injection timing curve. The solid design of the PowerPuck is CNC-milled out of T-6061 Aluminum, factory spec interlock connectors and a completely sealed wiring harness which provides for superior durability and a state-of-the-art look. Why to get DiabloSport PowerPuck?
CNC milled 6061-T6 aluminum body construction
Factory spec interlock connectors and a completely sealed wiring harness
PowePuck installs in nine easy steps and in less than an hour, no wires to cut, no seals will be broken and no feeding wires through the fire wall
PowerPuck is designed to put no additional strain on the Diesel injection pump. The rotary VP44 injection pump in the 24V Cummins has a preset electronic limit to the amount of fuel it will deliver. Since the PowerPuck is plugged in between the ECU and the injection pump, the PowerPuck is programmed to never exceed that limit.
Dyno Tested Performance Tunes
The PowerPuck was created with one thing in mind, POWER!
Average power gains are in 50 HP and 125-ft/lb TQ. The additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A PowerPuck equipped vehicle will notice significant improvements in drivability. The additional power will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
PowerPuck tunes re-map the:
Fuel Curves
Timing Curves
$165.00 AND ITS UR'S
Old Aug 12, 2010 | 01:28 AM
24vmatt's Avatar
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
