Stalling problems
Alright i got an automatic and its stalling out. I can start the truck up and if i dont give it some time to warm up ( even in summer) ill put it in gear and if i dont give it any pedal it will stall out, after i drive it for a while and come to a red light and sometimes it will stall out, if i turn the a/c on it will also stall and when i put the truck in reverse it also stalls without throttle, also if i turn the wheel either to the right or left as far as it goes the truck will stall, im not sure if my idling rpms are causing this because ive noticed my truck in gear sitting with my pedal on the break my rpms are around 500, without the a/c on, just wanted to know if the idling speed needs turned up a little bit or is there something else causing this. Thanks
i had the same problems with my 94...bumped up the idle so it idles around 750 with it in gear and brake on, problem solved
i had the same problems with my 94...bumped up the idle so it idles around 750 with it in gear and brake one, problem solved
Last edited by brindle_bull; Aug 5, 2010 at 10:36 PM. Reason: Automerged Doublepost
bump up the idle. if that doesnt completely solve(and you are still running factory injectors) your injectors could be worn out a bit. trust me i checked every thing in my fuel system and it still stalled... replaced injectors and it idled and ran perfect.
