voltage problems
Old Aug 5, 2010 | 10:14 PM
dan33klein's Avatar
Default voltage problems
the voltage guage on my truck is reading around 12 volts. i thought my grid heater solenoids were bad, so i unhooked the heaters. still problem. the batteries read 12 volts with the truck off. and 12 volts with the truck on. there is only 12 volts coming off the alternator to. voltage regulator?? the gen light has never came on?. thanks
Old Aug 6, 2010 | 12:24 AM
oglejust's Avatar
r u checking with ur gauge on the dash or with a voltmeter? if ur charging 12 volts i would think it'd eventually run out and not start. if i remember correctly there was a thread asking where the voltage regulator was.. most of which r in the alt but im thinking some1 said its in the pcm on these.
Old Aug 6, 2010 | 12:37 AM
cumminsCrazy's Avatar
regulator is in the pcm on 2nd gen trucks if everything is working properly its probably just an alternator.
Old Aug 6, 2010 | 07:19 AM
dan33klein's Avatar
i was using a multi meter.but the voltage guage is screwed up to. truck runs at like the first line on the guage. around 12 volts. gen light isnt on tho.
john grossman
10
Jan 12, 2019 08:58 PM
91firstgen
May 2, 2015 01:07 PM
robbyS
Apr 16, 2015 02:22 PM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
