Oil leak need help!
Old Aug 5, 2010 | 08:53 PM
jbuck's Avatar
Default Oil leak need help!
95 12 valve 2500 2wd with 218k. Have an oil leak on left side of engine under the injection pump. Can't tell where it is comming from. Previous owner said it was a headgasket leak. Not loosing any coolant at all so i am not sure it would be a head gasket. It was low two quarts of oil and before i added the oil the leak had stopped. Once I added the oil it started to leak. Is there a plug under the injection pump that may have backed out. Thanks in advance. Wonderful site with some very knowledgable people.
Old Aug 5, 2010 | 09:16 PM
00' Quad Cab's Avatar
I would check you vaccum pump gaskets or possibly the vac. pump rear seal.
Old Aug 5, 2010 | 09:55 PM
jbuck's Avatar
Default oil leak
The leak is above the vacuum pump. i can see oil running down the side of the block but i cant see up behind the injection pump.
Old Aug 5, 2010 | 10:07 PM
dan33klein's Avatar
theres this plate that bolts to the side of the block by the injection pump. there prone to leaking and are a bitch to fix. someone with more knowledge and the name of it will chime in soon
Old Aug 5, 2010 | 10:17 PM
tiremann9669's Avatar
Or the oil line to the Injection pump
Old Aug 5, 2010 | 11:09 PM
tltruckparts's Avatar
i had the side cover gasket leak on mine. not too hard to fix if you know how to pull the pump off.
Old Aug 5, 2010 | 11:16 PM
FastCR's Avatar
I did mine as well. I've been told it's possible to do without pulling the pump off, but it looked at lot easier to pull the pump to me so I did.
Old Aug 6, 2010 | 07:59 AM
jbuck's Avatar
That's probably the leak. Thanks guys for the advice.
cummins Pride
Sep 28, 2015 12:11 PM
BKID
Jul 25, 2015 07:59 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
