Flexalite Fan
Old Aug 5, 2010 | 03:39 PM
300ft.'s Avatar
Default Flexalite Fan
has anyone had trouble with the flexalite fans causing the engine to idle improperly? mine runs fine until the fan kicks on and then it idles almost like its missing?????????????
Old Aug 13, 2010 | 04:16 PM
300ft.'s Avatar
so i guess noone can help
Old Aug 13, 2010 | 10:41 PM
dodgeram082500's Avatar
the only thing I've heard is the engine will over heat towing but its all hear say until you actually have one
Old Aug 16, 2010 | 12:27 PM
ForcedInduction's Avatar
High alternator load.
Consider having a different temperature switch for each fan so that only one fan is running unless the temperature climbs further.
Old Aug 16, 2010 | 10:30 PM
big bad diesel 416's Avatar
Site Sponsor
well my bosh fans pull 25amps each I cam manually run bolth and have no probs check the ALT
Old Aug 17, 2010 | 05:55 PM
300ft.'s Avatar
ok after talking with flexalite, i was told that the magnetism of the fan motors when on are disrupting the signal of the crank position sensor confusing the ecm into changing the injection timing... they told me that they have had half a dozen calls with the same issue with the 6.7's yeehaa
oh yeah, they dont have any solution except for to re install the stock fan until they come up with a solution
Old Aug 17, 2010 | 07:32 PM
dangit that kinda sucks hope they get it fixed for you soon 300ft
Old Aug 17, 2010 | 11:56 PM
Site Sponsor
Try putting something on the CPS like a shop rag zip tied on or something of the sort to brake the field (just a thought)
Old Aug 18, 2010 | 12:09 AM
Rustin's Avatar
Old Aug 19, 2010 | 03:12 PM
Jerry rig some EMI shielding for the motors and/or sensor.
