FICM
Old Aug 4, 2010 | 05:06 PM
groverdiesel's Avatar
Default FICM
2005 F-350 4x4 throwing all P codes for inj. circuit low. All injectors replaced prior to truck dieing. Any suggestions. thanks
Old Aug 4, 2010 | 05:38 PM
paul h's Avatar
I would check the FICM voltage and all the injector wire harness for chafe spots or shorts.
The FICM has to put out 48 volts to open and close the ingectors and can do many wierd things if it is bad.
There are several threads on several forums giving FICM check and repair info
Old Aug 11, 2010 | 06:32 PM
kyle43335's Avatar
most likely your ficm is bad. low voltage codes for all 8 cylinders. is ficm death
Old Aug 18, 2010 | 12:37 PM
F350BRO's Avatar
Is the FICM expensive and do you have to redownload the program if replaced???
Old Aug 18, 2010 | 01:53 PM
Rustin's Avatar
The FICM is quite costly. It is a dealer only part that I know of, and to have just re-flashed should be no more then $150.00 depending on location and dealer. have you made sure there is no shorts between the FICM and ECM?
Old Aug 18, 2010 | 02:49 PM
CSIPSD's Avatar
Talk to Power Hungry Performance here on this site... They have and reprogram them. I do not know the cost off the top of my head, but that would be my first call. I would NOT go to the dealer for this part.
Old Aug 18, 2010 | 03:43 PM
Lange503's Avatar
you can get it from the dealer yeah... but it will be more expensive, like CSIPSD said, talk to PHP and get one, will be cheaper and have a better program on it for damn sure
Old Aug 18, 2010 | 08:09 PM
scrotom's Avatar
swamps has them also.
Old Aug 19, 2010 | 08:34 PM
paul h's Avatar
New Blank FICM: Dealer list $700
will need installed (unknown what the dealer service department will charge)
programed $ 150
Total $850 +/-
Old Aug 19, 2010 | 10:53 PM
F350BRO's Avatar
Holy mother of all things that are FORD....I am just going to fix my own....the solder job looks really simple...I think they use lead free solder so they break off easy.
keith63
Mar 25, 2015 04:50 PM
keith63
6.0L Performance
Mar 18, 2015 12:35 PM
makuloco2000
Feb 15, 2015 02:31 PM
shawnecarter
Jan 11, 2015 03:19 PM
Stroker64
6.0L Performance
Nov 12, 2014 07:32 PM
