P1633 KAM problems
Old Aug 4, 2010 | 08:14 AM
spetersen502's Avatar
Default P1633 KAM problems
2005 Ford F-350 4X4 Died while driving down the road and this is the code it threw and now it wont start, but it will crank over. All data is telling me to check for loose connections at the PCM, also check the voltage at the body harness connector pin 40 (harness side and ground) on that note which of the three connections on the PCM is the body harness connector. I also found no loose connections and every time I clear the code it comes back, any suggestion. Thank You
Old Aug 4, 2010 | 10:08 AM
Snowman's Avatar
MR.3K
Thats the same prblem i'm having with the truck i'm working on!! Can't seem to figure it out. Everything seems to check out ok.
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
moroza
Mar 29, 2015 05:37 PM
Tucker126
Jan 2, 2015 08:09 AM
JRB1960
Dec 1, 2014 09:24 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
